Mastercam 2027: Smarter Workflows, Faster Programming, and a Glimpse into the Future
The Mastercam 2027 rollout series delivered more than a list of new features. Across two sessions, the team showcased how Mastercam continues to evolve around a simple goal: helping programmers, machinists, and manufacturers get from design to finished part faster, with less manual effort and greater confidence. Key themes included workflow simplification, advanced multi-axis machining capabilities, AI-powered assistance, and exciting innovations that point toward the future of CAM.
Built for Today’s Manufacturing Challenges
With technology advancing faster than ever, Mastercam’s semiannual release cadence allows new capabilities to reach users sooner. Mastercam 2027 builds on the foundation established with 2026.R2, adding practical improvements designed to reduce programming time, improve toolpath quality, and streamline everyday workflows.
The updates span everything from CAD and machine setup workflows to multi-axis machining, tool management, simulation accuracy, and automation.
Multiaxis Programming Takes Another Leap Forward
One of the biggest areas of investment in Mastercam 2027 is multiaxis machining.
More Control with Unified Toolpaths
Unified toolpaths received several major enhancements, giving programmers more flexibility when creating complex surface-finishing operations. New Guide Parallel and Guide Morph strategies provide greater control over tool motion and allow users to achieve smoother transitions while reducing the need for multiple toolpaths.
Additional enhancements include:
  • Automatic morph support for smoothing difficult transitions
  • Part Awareness technology to improve initial cut patterns
  • Expanded wireframe toolpath control options
  • Improved multi-axis pocketing with fixture-aware collision checking
  • Rest machining capabilities for finishing hard-to-reach areas
  • Extended toolpath options for improved surface finish quality
The result is greater efficiency when programming molds, aerospace components, blisks, impellers, and other complex surfaces.
Swerve and Blade Expert Enhancements
Mastercam’s Swerve toolpath now includes new multi-cut strategies such as Align with Longest Contact Line and Align with Cutting Part, helping deliver more consistent cutter engagement and surface finish.
Blade Expert users will also benefit from new edge-finishing capabilities, expanded feedrate control options, and support for flat and bull-nose endmills.
Mastercam Deburr Gets Even More Powerful
Few toolpaths received as much attention in the rollout as Mastercam Deburr.
Already a customer favorite, Deburr now includes:
  • Automatic machining direction options
  • Spiral closed-contour motion
  • User-selected chain order preservation
  • Follow Curve Chaining functionality
  • Advanced edge filtering
  • Backside chamfer tool support
These enhancements provide more control over edge finishing operations while reducing programming time and tool motion inefficiencies.
For shops processing complex castings, machined components, or parts with numerous edges, the updates make Deburr more intelligent and easier to configure than ever before.
Smarter CAD and Programming Workflows
Mastercam 2027 also introduces several usability improvements that eliminate common frustrations.
Easier Plane Creation
The updated plane management interface simplifies tool plane selection and allows users to create new planes directly within the toolpath workflow without leaving the operation. This reduces interruptions and keeps programmers focused on machining strategies rather than setup tasks.
Enhanced Curve One Edge Functionality
A standout CAD enhancement is the redesigned Curve One Edge workflow. Users can now leverage live edge, face, and loop selection while easily adding or removing desired geometry. The result is a much faster and more intuitive method for creating wireframe from solids, surfaces, and meshes.
Improved Verify Selection
Verify Selection has also expanded its capabilities, allowing users to interact with geometry more effectively while working inside dynamic transform functions and other workflows.
Better Machine Definition and Mill-Turn Setup
For advanced users, machine-definition management received a complete modernization.
The new interface clearly separates local and global machine definitions while introducing:
  • Modern UI panels
  • Improved kinematic tree organization
  • Access-combination validation
  • Read-only file protection options
  • Simplified configuration workflows
Mill-Turn users will especially appreciate the redesigned Machine Group Setup environment, which offers:
  • Interactive graphical feedback
  • Configuration saving and loading
  • Easier spindle and stock setup
  • Real-time validation
  • Simplified plane management
These updates make complex machine configuration tasks significantly easier to manage.
More Accurate Tool Definitions and Simulation
Mastercam 2027 expands support for modern cutting tools with enhanced tool definition capabilities.
New support includes:
  • Tapered and reduced-shank tool profiles
  • Enhanced dovetail cutter definitions
  • Tapered reamers
  • Additional center drill configurations
  • Expanded 3D lathe tool feed and speed control options
Combined with stock model enhancements that improve representation of actual flute lengths and tool engagement, these updates help improve simulation accuracy and reduce surprises during machining.
AI Continues to Evolve with Mastercam Copilot
Artificial intelligence continues to move from buzzword to practical shop-floor tool.
Available through Mastercam Connect, Mastercam Copilot serves as an in-product programming assistant designed to help users find information faster and automate repetitive tasks. Rather than replacing programmers, Copilot helps eliminate tedious work.
Copilot can:
  • Search documentation, training, and Mastercam University content
  • Launch commands directly
  • Help users find specific workflows
  • Modify parameters across multiple operations
  • Assist with machine group creation and setup tasks
By combining access to help resources, videos, and practical programming actions, Copilot is becoming a valuable productivity companion inside Mastercam.
EverPath Technology: A Glimpse at the Future of CAM Programming
Perhaps the most exciting announcement across both webinars was the continued development of EverPath Technology, Mastercam’s next-generation toolpath platform.
Unlike traditional CAM workflows that require constant recalculation and regeneration, EverPath Technology introduces a dramatically different experience:
  • Live toolpath updates as parameters change
  • Immediate visual feedback
  • Interactive toolpath editing
  • Dynamic collision avoidance
  • Built-in user assistance with contextual guidance
  • Editable toolpath history and refinement tools
Instead of making a change, regenerating, and checking results repeatedly, programmers can see toolpath updates instantly and refine only the areas that need adjustment.
The Mastercam team described EverPath Technology as one of the most significant technology advancements in company history, and public beta access is already available through Mastercam Connect ahead of its planned inclusion in Mastercam 2027.R2.
Beyond Programming: The Mastercam Manufacturing Experience
Another key takeaway from the rollout series was that programming is only one part of the manufacturing process.
The Mastercam Manufacturing Experience highlights how manufacturers can connect quoting, tooling, programming, simulation, optimization, and inspection into a more seamless workflow by leveraging technologies across the Sandvik portfolio.
The message is clear: the future of manufacturing lies not just in better CAM software, but in creating connections across the entire production lifecycle.
Looking Ahead
Mastercam 2027 delivers meaningful improvements that help users program faster, machine more efficiently, and work with greater confidence. Whether it’s expanded multi-axis capabilities, smarter deburring, more accurate simulation, AI-powered assistance, or the revolutionary potential of EverPath, the release reflects a continued focus on solving real-world manufacturing challenges.
For shops looking to increase productivity and stay competitive, Mastercam 2027 isn’t just another annual release. It’s a preview of where manufacturing software is headed next.
