What We Learned: Mastercam Migration Webinar Recap
Staying current with Mastercam releases is not just about accessing new features, it is about protecting the customizations, workflows, and efficiencies shops rely on every day.
During our “Mastercam Migration Made Easy” webinar, Mastercam’s Manager of Global Applications Engineering, Chad Chmura, walked attendees through the ins and outs of the migration process: what it is, why it matters, and how to make it faster, safer, and easier for everyone on your team.
Below is a recap of the key insights and practical guidance shared during the session.
Why Migration Matters More Than Ever
Every year, Mastercam delivers major performance updates, feature enhancements, and expanded integrations with partner technologies. With those improvements come underlying file and versioning changes, making migration essential.
Skipping migration puts users at risk of losing:
  • Customized tool libraries
  • Post processor modifications
  • Interface layouts and workspace preferences
  • Machine and control definitions
  • Operations defaults that streamline programming
  • Stability and compatibility with new tech integrations
Even if your current version “works fine,” staying on outdated releases results in growing disadvantages: from lack of support to declining compatibility with the tools your shop depends on.
Migration Does Not Have to Be Complicated
Modern Mastercam releases undergo extensive beta testing long before they reach users, meaning many concerns about “waiting for the first update” are less relevant today.
Users have two migration options:
1. Basic Mode
A one-click, migrate-everything approach.
  • Best for: new users or simple environments.
  • Downside: can take longer and may migrate files you do not actually need.
2. Advanced Mode
Allows you to control:
  • Which file types migrate
  • Custom source and destination paths
  • Whether to migrate only selected elements (posts, tool libraries, ops defaults, etc.)
Advanced mode can dramatically reduce migration time and eliminates unnecessary clutter or duplicates.
Understanding the Mastercam File Ecosystem
There are two main categories of files involved in a typical setup:
myMastercam Files
These are personal, user-specific customization files, including:
  • Interface layout (workspace)
  • System configuration settings
  • User-saved part files
  • Local defaults or libraries not shared across a team
Shared Mastercam Files
These affect an entire shop or group of programmers, such as:
  • Post processors
  • Machine definitions
  • Control definitions
  • Shared tool libraries
Knowing what each file type does and how they relate makes troubleshooting migration issues far easier.
What is Worth Migrating (and What is Not)
Not everything needs to move when upgrading to a new version. Some files are essential to bring along, others depend on how your team works, and a few can usually be left behind without issue.
Definitely migrate:
  • Post processors – any customizations are essential
  • Machine definitions – core to every CAM setup
  • Control definitions – stores critical linked settings
  • Operations defaults – huge timesavers for power users
  • Tool libraries – especially if customized with real shop data
Often unnecessary to migrate:
  • Part files – opening and saving them in the new version works fine
  • NCI files – little value in duplicating them between releases
Avoiding Downtime: Common Challenges & Solutions
One of the biggest concerns raised during the webinar was downtime. Attendees’ familiar worries: unexpected bugs, performance inconsistencies, broken links, or simply losing too much time migrating.
These challenges are common, but they are also avoidable with the right approach. The webinar highlighted several practical strategies to keep migration smooth and disruption to a minimum.
1. Minimize downtime by centralizing shared files
Instead of every programmer migrating their own file set, designate one migration “owner.” Host shared files on a network location so:
  • They only need to be migrated once
  • Everyone benefits from consistent defaults
  • File connection issues are reduced dramatically
2. Understand file connection paths
Machine definitions sit at the top of a structured hierarchy. A single broken link—from machine def → control def → post → ops defaults can cause workflow interruptions. Migrating with awareness of these links helps avoid errors.
3. Keep proven toolpaths
Older toolpaths do not regenerate automatically. If a path is proven and you want to preserve it:
  • Lock it from regeneration
  • It will remain untouched even in the newer version
4. Do not wait five years between updates
Migration is only validated for the previous three versions. Skipping too many releases means:
  • You must migrate through an intermediate version
  • The process becomes significantly more complex
Advanced Tips for Power Users
For teams looking to go beyond the basics, the webinar also shared several tips that can make day-to-day workflows smoother and migrations far less painful.
Organize your file structure
  • Avoid mixing posts, machines, and other components inside local part folders.
    Clear, consistent organization = easier migration + fewer mistakes.
Pin key folders in Windows Quick Access
  • Save time navigating to Shared Mastercam and myMastercam directories.
Create multiple machine-specific versions of the same machine definition
  • This is useful when multiple identical machines exist, but each maintains its own tool library.
Use MXM Content Files or Zip2Go
  • These are powerful packaging tools for transferring or backing up:
  • Posts
  • Tool libraries
  • Machine and control defs
  • Custom defaults
  • Workspaces
They also migrate cleanly into new Mastercam versions.
Resetting bad customizations
  • If a workspace or setting gets corrupted or misconfigured:
  • Rename or delete the offending file
  • Mastercam will recreate a clean default version automatically upon restart
Soon to Come: Mastercam 2026.R2
The webinar wrapped with a preview of Mastercam 2026.R2, arriving February 9th. The biggest highlight? No migration required!
Mastercam 2026.R2 installs cleanly over existing setups while retaining your current files and customizations; a highly requested enhancement aimed at reducing IT friction and improving adoption across shops.
Final Takeaways
Migration does not need to be disruptive. With a clear understanding of file types, a thoughtful migration approach, and centralized management, shops can update Mastercam smoothly and confidently each year.
The benefits:
  • Improved performance
  • Access to modern features
  • Consistent programming standards
  • Reduced support issues
  • Better integration with partner technologies
  • Protection for your shop’s tribal knowledge
As Chad emphasized: Updating regularly keeps your shop competitive, efficient, and ready for the next generation of CAM technology. Connect with your local Mastercam expert today to make sure you stay up to date!
