Streamline Your Machining Workflow with the CoroPlus® Tool Library Add-in for Mastercam
From programming accuracy to tool management, every step matters. That’s why integrating powerful digital tools into your CAM environment can make a measurable difference.
The Sandvik Coromant CoroPlus® Tool Library add-in for Mastercam is designed to do exactly that: bringing seamless access to tooling data directly into your programming workflow so you can work smarter, faster, and with greater confidence.
What Is the CoroPlus Tool Library Add-In?
The CoroPlus Tool Library add-in connects Mastercam users to Sandvik Coromant’s comprehensive, cloud-based tooling database. Instead of manually building tools or searching through catalogs, you can import accurate, manufacturer-grade tool data directly into your Mastercam projects.
The result? A more streamlined workflow from programming to production.
Key Benefits for Mastercam Users
  • Access Verified Tool Data Instantly
Eliminate guesswork with direct access to up-to-date tooling assemblies, cutting data, and parameters from Sandvik Coromant’s extensive library. Spend less time creating tools and more time programming.
  • Improve Programming Accuracy
Accurate tool geometry and cutting data help reduce errors, minimize rework, and improve simulation reliability, so what you see in Mastercam is what you get on the machine.
  • Boost Productivity
By removing repetitive manual entry and simplifying tool setup, programmers can significantly reduce setup time and focus on higher-value tasks.
  • Enhance Collaboration Across Teams
With standardized tool data, teams can maintain consistency across programming, setup, and machining operations, reducing miscommunication and improving overall efficiency.
  • Stay Up-to-Date with the Latest Tooling
The cloud-based library ensures you always have access to the latest Sandvik Coromant tooling innovations without needing manual updates.
Why It Matters
Disconnected workflows and outdated tooling data can slow down even the most experienced programmers. The CoroPlus Tool Library add-in bridges that gap, enabling a fully digital, connected machining process right inside Mastercam.
Whether you are working on complex parts or high-volume production, having reliable tool data at your fingertips helps you maintain accuracy and stay competitive.
See It in Action: Join Our Upcoming Webinar
Want to see how it works in a real-world Mastercam environment? Register for our upcoming webinar where you will learn how to:
  • Integrate the CoroPlus Tool Library into your Mastercam workflow
  • Quickly find and import the right tools for your job
  • Improve efficiency and reduce programming time
  • Leverage digital tooling data for better machining outcomes
Don’t miss your chance to explore this powerful integration firsthand and take the next step toward a more connected, efficient programming workflow.
