Streamline Your Deburring Process with Mastercam Deburr
Manual deburring and edge finishing slow production, raise labor costs, and reduce consistency. However, by automating the process, you can streamline operations and improve quality.
The Deburring Challenge
Burrs aren’t just an inconvenience—they’re a genuine problem that impacts your entire operation. These unwanted protrusions prevent proper workpiece alignment in fixtures, compromise surface finish quality, and create safety hazards. For machine shops focused on maximizing productivity and minimizing costs, manual deburring represents a significant bottleneck that eats into profitability.
The traditional approach of hand deburring is labor-intensive and inconsistent. Programming complex deburring toolpaths manually is time-consuming and requires expertise that many shops struggle to maintain. Furthermore, advanced multiaxis solutions often carry high licensing costs, making them inaccessible for many operations.
Introducing Mastercam Deburr
Mastercam Deburr is a comprehensive 3-axis Add-On solution designed to transform how you handle edge treatment and deburring. Available for Mill, Mill 3D, Router, Router 3D, and Mill-Turn users via CONNECT subscription, it delivers pro results.
Active Mastercam CONNECT users get free access to the Deburr Add-On as long as you keep your Maintenance plan active. That means no additional licensing fees—just enhanced capability that’s already included with your subscription.
What makes Mastercam Deburr different?
The solution leverages intelligent deburr cycles in a familiar 3-axis environment, using simplified controls that your team already understands. Automatic edge detection dramatically reduces programming time, while support for multiple tool types—including Chamfer Mill, Dove Mill, Ball Mill, Lollipop Mill, and Taper Mill with Full Radius—gives you flexibility across various machining strategies.
Real Benefits for Your Shop
Save Time and Labor
Automatic edge detection and streamlined programming mean less time at the computer and virtually no time spent with files and scrapers. What once took hours of manual work now happens automatically during the machining cycle.
Achieve Precision Consistently
Meet exact tolerances and edge specifications every time. The multiple pass functionality allows you to take several passes with ball mills to form precise chamfers and rounds, ensuring repeatability that manual methods simply cannot match.
Optimize Your Tooling Investment
With support for a wide range of tool geometries and the ability to use tools you already have, Mastercam Deburr helps you maximize your existing tooling resources without requiring specialized deburring equipment.
Improve Part Quality
Programmed, consistent edge treatment ensures superior surface finishes, precise fixture alignment, and parts that meet specifications right off the machine, reducing rework and inspection time. By minimizing manual handling, you also lower the risk of damage or dimensional variation, helping you deliver higher-quality parts faster and more reliably, with fewer touchpoints and great throughput.
Easy Integration, Immediate Results
One of the most compelling aspects of Mastercam Deburr is how easily it fits into your existing workflow. If you’re already running Mastercam 2D or 3D Mill, Router, or Mill-Turn products with CONNECT, adding deburring capabilities requires no dramatic changes to your processes or extensive retraining of your team.
The solution works within the environment your programmers already know, eliminating the learning curve that often accompanies new software implementations. This means you can start seeing benefits almost immediately after deployment.
Getting Started is Simple
Ready to activate Mastercam Deburr? Simply reach out to your Mastercam representative to enable this powerful Add-On for your system.
As a CONNECT customer with an active Maintenance plan, there’s no additional cost—just contact your rep to get started and they’ll walk you through the activation process.
The Bottom Line
In today’s competitive manufacturing environment, shops that can reduce costs while improving quality gain a significant advantage. Mastercam Deburr addresses key priorities—enhanced productivity, elimination of manual deburring, shortened programming time, and accessible pricing—in one integrated package.
By automating what has traditionally been manual work and bringing precision to what has often been approximation, Mastercam Deburr delivers measurable savings in both labor and tooling while elevating part quality and consistency across your production.
And remember: If you’re already a CONNECT customer maintaining your subscription, this powerful capability is already available to you at no extra cost.
Manual deburring is slow, costly, and inconsistent. Mastercam Deburr automates edge finishing to improve quality and efficiency. It’s a 3-axis Add-On for Mill, Router, and Mill-Turn systems with a CONNECT subscription. No multiaxis license is needed.
Activate through your current Maintenance plan. Start seeing productivity gains immediately. Hand deburring requires time and skill many shops can’t maintain. Multiaxis solutions are often expensive and out of reach. Mastercam Deburr offers a simple, cost-effective alternative for consistent results.
Ready to activate Mastercam Deburr and transform your edge treatment processes? Contact your Mastercam representative today to enable this Add-On and schedule a demonstration.
