Drivers and Utilities
These drivers and utilities have been tested and released by the Quality Control Department. Follow the instructions given in the ‘info’ column of each download for install help.
Send any comments or questions here.
Hardware Licensing
| ITEM / DESCRIPTION | POSTED | SIZE | INFO |
| HASP Drivers For Mastercam X2 and Newer | 06/08/2020 | 20 MB | Use this product to install HASP drivers on Windows 7 or later. To install: Click on the Sentinel_LDK_setup.zip link and save it to your computer. Extract the .zip file to your desktop. Double-click on HASPUserSetup.exe. Follow the installation instructions. |
| HASP Update Utility HASPX.exe-Version 2026 | 07/01/2025 | 1.6 MB | Use this product to install HASP codes or read your HASP.To install: Click on the haspx.zip link and save it to your computer. Extract the contents of the *.zip file to your desktop. Double-click on the .exe to launch the application. You must have HASP drivers installed to run this executable. |
| NetHASP Update Utility NHASPX.exe-Version 2026 | 07/01/2025 | 1.5 MB | Use this product to install NetHASP codes or read your NetHASP.To install: Click on the Nhaspx.zip link and save it to your computer. Extract the contents of the *.zip file to your desktop. Double-click on the .exe to launch the application. You must have NetHASP drivers installed to run this executable. This must also be run locally on the NetHASP server to update codes. |
| NetHasp License Manager | 01/17/2019 | 14 MB | Use this product to install Mastercam License Manager.To install: Click on the mastercam-licensemanager.zip link and save it to your computer. Extract the .zip file to your desktop. Double-click on mastercam-licensemanager.exe to run the application. |
| NetHASP Monitor | 01/17/2011 | 2 MB | To install:Click on the mastercam-monitor.zip link and save it to your computer. Extract the .zip file to your desktop. Double-click on mastercam-monitor.exe to run the application. |
| HASP Drivers For Mastercam X and older | 09/09/2007 | 4 MB | Use this product to install HASP drivers for Mastercam X and older.To install: Click the drivers_x.exe link and save the download to your computer. When the download is complete, double-click on the *.exe file. Follow the installation instructions. Note: The HASP key should be disconnected during the driver installation. |
Software Licensing
| Mastercam Activation Wizard Setup Version 2027 | 9/22/2026 | 433MB | This utility will install the Mastercam Activation Wizard. The program allows the activation of Mastercam products using an activation code. |
| CodeMeter 9.10 Runtime Installation | 08/26/2026 | 174 MB | To install: Click the CodeMeterRuntimeLatest.exe link and save the download to your computer. When the download is complete, double-click on the *.exe file. Follow the installation instructions. |
Utilities
| System Inspector Utility | 05/28/2020 | 2 MB | This is a small utility used to gather information and diagnose basic Mastercam-related problems on a user’s system. The program generates a text file that can be sent to Technical Support to help troubleshoot issues.To use the Inspector Utility: Click the System Inspector Utility link to save inspector-utility-20200528.zip to your computer. Extract the contents of the .zip file to your desktop. Double-click McamInspect.exe. Choose a Mastercam version from the drop down list. Click the “Sys Info” button to gather system and Mastercam information. Click the “Analyze” button to check for licensing problems. Click the “Create report” button to generate the text report file. It is created in the same location as “McamInspect.exe”. |
