Webinar: How CoroPlus® and Mastercam Are Transforming CAM Workflows
Manufacturers today face a familiar challenge: doing more with fewer resources while managing increasingly complex parts, materials, machines, and tooling. In our recent joint webinar with Sandvik Coromant, experts Jesse Trinque (Mastercam) and Mosharraf Hossain (Sandvik Coromant) explored how digital tooling solutions can help manufacturers overcome these challenges and create a more efficient, connected workflow.
Here’s a recap of the key takeaways.
The Manufacturing Challenge: Complexity Is Growing
Modern manufacturing environments are navigating several trends at once:
  • More advanced materials that are stronger, lighter, and more difficult to machine
  • Increasingly complex part geometries
  • Sophisticated machine tools that require specialized programming skills
  • Ongoing workforce and skills-gap challenges
  • Pressure to improve sustainability and efficiency
At the same time, many shops remain heavily dependent on a small number of highly skilled employees who often become bottlenecks in the programming and tooling process.
Finding, downloading, and validating tooling data can consume valuable engineering time, while inaccurate or incomplete tool models can lead to costly collisions, rework, and setup delays.
Interestingly, webinar poll results showed that attendees identified two major pain points above all others:
  1. Reliance on a few key skilled individuals
  1. Time spent searching for and downloading tooling data
These are exactly the kinds of challenges digital tooling solutions are designed to address.
Why Accurate Tool Data Matters
A seemingly simple machining task involves many interconnected variables, including:
  • Feature geometry
  • Material type
  • Machine capabilities
  • Cutting tools
  • Machining strategy
Finding the right combination can be difficult even for experienced programmers. Digital tooling platforms help capture and apply years of manufacturing knowledge, making it easier to identify the right solution while reducing risk.
Accurate tooling data is especially important in turning applications. Unlike rotating milling tools, turning tools often require highly detailed 3D representations to accurately simulate tool motion, detect collisions, and validate machine setups. Without that data, programmers may spend significant time manually creating tool assemblies and verifying them before programming can even begin.
Introducing CoroPlus® Tool Library
The centerpiece of the webinar was the CoroPlus® Tool Library, Sandvik Coromant’s digital tooling solution that streamlines the flow of tooling data directly into CAM systems like Mastercam.
Key capabilities include:
  • Access to up-to-date digital tooling data
  • Tool recommendations based on application requirements
  • Automatic assembly of complete tool setups
  • ISO-standardized tooling information
  • Transfer of tooling and cutting data directly into CAM software
  • Integration with shop-floor inventory and purchasing workflows
Rather than searching multiple websites for individual tool components, users can build complete tool assemblies within CoroPlus and transfer them directly into Mastercam with just a few clicks.
Smarter Tool Selection Through Application-Based Recommendations
One of the standout demonstrations showed how users can start with the machining application instead of the tool by entering factors such as:
  • Workpiece material
  • Feature type
  • Geometry dimensions
  • Machine conditions
CoroPlus can recommend appropriate tooling and cutting data automatically. The platform currently supports more than 20,000 materials and can even identify existing tool assemblies already available in the shop, helping users maximize inventory utilization before purchasing new tools.
Users can also compare cutting conditions, evaluate machining performance, and review sustainability metrics such as carbon emissions associated with different tooling choices.
Highlighting Advanced Turning Technologies
The webinar also explored two innovative Sandvik Coromant technologies that benefit significantly from accurate digital tool data.
PrimeTurning™
PrimeTurning reimagines traditional turning by allowing machining in multiple directions with specially designed inserts and toolpaths. Benefits include:
  • Productivity increases of more than 50% compared to conventional turning
  • Higher feed rates
  • Better chip control
  • Longer insert life
  • Improved machine utilization
  • Reduced downtime for tool changes
The unique geometry and motion of PrimeTurning tools make accurate 3D tool models especially important for verification and simulation.
Y-Axis Turning
Y-axis turning takes innovation even further through simultaneous three-axis turning operations. Advantages include:
  • Roughing and finishing with a single tool
  • Improved stability through optimized force direction
  • Reduced tool changes
  • Ability to machine complex profiles with fewer transitions
  • Enhanced productivity when combined with PrimeTurning
These advanced strategies require sophisticated programming and simulation capabilities, making reliable tooling data essential.
Bringing CoroPlus Directly Into Mastercam
The live demonstration showcased the seamless integration between CoroPlus Tool Library and Mastercam.
Instead of manually:
  • Downloading STEP models
  • Building tool assemblies
  • Defining cutting profiles
  • Configuring orientations
  • Validating geometry
Users can:
  1. Create or select a tool assembly in CoroPlus.
  1. Import it directly into Mastercam.
  1. Automatically generate tool definitions and geometry.
  1. Apply recommended cutting data.
  1. Begin programming immediately.
What previously could take 20–30 minutes per tool can be reduced to a matter of seconds. For larger jobs with multiple setups, the time savings can be substantial.
Improving Simulation Accuracy and Setup Confidence
Mastercam users also benefit from more realistic simulation environments. With complete 3D tool assemblies, programmers can:
  • Validate machine movements
  • Detect collisions earlier
  • Verify turret and spindle clearances
  • Optimize setup configurations
  • Improve confidence before code reaches the shop floor
For multitasking, mill-turn, and complex turning applications, this level of accuracy can significantly reduce programming risk and machine downtime.
Watch the Webinar On-Demand Today
If you missed the live session or would like to revisit the key insights, register today to access the on-demand recording and watch at your convenience.
Interested in more of our on-demand webinars? Click here and see what you can learn today!
