CAM Trends for 2025 – Doing More with Less
By Dave Miller, Manager of Sales Engineering, Mastercam
In the manufacturing field today, sticking to “the way we’ve always done it” just won’t cut it anymore. With cutting-edge tools like AI, IoT-enabled equipment, and advanced CAM software reshaping the shop floor, agility and interconnectivity will be key to successfully reimagining traditional processes. If you’re ready to embrace change and outpace the competition, Mastercam is here to help. Let’s take a closer look at five trends in 2025—and how you can stay ahead.
1. Complex Machinery: Smarter Tools, Better Results
Multiple setups are no longer the norm. Thanks to advanced 5-axis lathes and high-tech milling machines, manufacturers can now consolidate tasks, streamline operations, and save valuable time and space. These sophisticated machines make multitasking a breeze, allowing you to produce precise parts faster than ever.
Making the most of complex machinery requires the right CAM software to unlock their full potential. These systems are designed to provide adaptable and efficient solutions for a wide range of manufacturing applications. A key feature of this software is advanced toolpath technology, which optimizes the motion of cutting tools to shape materials such as metal, wood, or plastic. This process focuses on achieving smooth, efficient cutting motions while addressing critical factors like preserving tool life and producing high-quality surface finishes.
That’s where Mastercam comes in—our intuitive tools make navigating advanced setups easier, while our training resources ensure your team is ready to meet the challenge. The payoff? Enhanced productivity and a competitive edge that sets you apart.
2. AI and Automation: Your Shop Floor Ally
Artificial intelligence (AI) and automation programming are reshaping manufacturing, significantly enhancing efficiency and precision. Imagine cutting programming time from 16 minutes to just seconds or letting AI handle micro-tasks like tool selection and fixture design. The key is striking the right balance between cutting-edge tech and practical application.
A critical aspect of advancing manufacturing automation is building a robust “digital thread” which allows data to flow seamlessly across the entire production lifecycle. For example, AI-driven systems can analyze 3D drawings to identify optimal manufacturing strategies, selecting from hundreds of available toolpath approaches. By automating such decisions, manufacturers can ensure the best methods are applied to each part, minimizing errors and improving quality.
Mastercam’s software is designed with the real-world shop in mind, offering a suite of over 100 motion calculation strategies, each tailored to specific manufacturing needs. This helps ensure that the most effective methods are applied to each section, streamlining workflows and enhancing the consistency and quality of the finished product.
3. Turnkey Solutions: Out-of-the-Box Interface
Back in the day, machinists and programmers would spend hours right at the machines, tweaking settings and making sure everything ran just right. In 2025, there’s a growing push for ready-to-go solutions that take out the guesswork and cut down on all that manual effort.
Central to this evolution is the rise of interconnected systems that communicate seamlessly. The Internet of Things (IoT) is creating a more connected world – including the manufacturing space. Expect a stronger focus on enhancing machine-to-machine communication for greater productivity.
Mastercam’s CAM software facilitates this interconnectivity by helping to link systems and processes. For instance, tools can be configured and validatedvirtually, ensuring the correct setup before any operation begins. This means fewer surprises and a higher chance that everything will work as intended when it’s time to use the CNC machine. The result? Fewer errors, less downtime, and more time to innovate.
4. Additive Manufacturing: A World of Possibilities
From aerospace to custom consumer products, additive manufacturing is enabling the creation of parts once thought impossible. The potential is enormous, and the market is growing fast, with projections exceeding $83 billion by 2030.
Legendary guitar maker Dean Zelinsky recently partnered with Mastercam and our collaborators to create a custom electric guitar shaped from 140 pounds of solid aluminum. To form the neck of this innovative guitar, the team took 3D printing to another level. They used the technology to produce the support structure and fixtures necessary to manufacture the honeycomb design. This kept the guitar lightweight yet durable while maintaining the instrument’s functionality and sound quality.
5. Harnessing High-Speed Machining
High-speed machining (HSM) is a metal-cutting process that uses high spindle speeds and feed rates to remove material quickly, without compromising part quality and precision.
HSM is transforming how manufacturers approach material removal, making it possible to achieve faster cycle times and greater precision. By using lighter cuts and low-pressure techniques, shops can significantly boost efficiency.
Looking Ahead: Innovate or Risk Falling Behind
Already using HSM? The next step is optimizing your processes with AI, digital twins, and other advanced tools. The manufacturing landscape is changing, and the most successful shops are those willing to evolve.
Ready to lead the charge in 2025? At Mastercam, we’re committed to helping you navigate this exciting future. Our software, expertise, and support are designed to empower you to push boundaries and rethink what’s possible.
