Version 2021
Traductores Mastercam 2021
Mastercam permite importar y exportar archivos en distintos formatos.
En las tablas que aparecen a continuación puede comprobar cuáles son las versiones de formato de archivo que son compatibles con cada versión de Mastercam.
Puede enviarnos cualquier comentario o pregunta al servicio de asistencia de Mastercam.
Version 2021
TRANSLATOREXTENSIONSVERSIONR/WSOLIDSINFO
3DPDF.PDFn/aWThe result is not viewable in a browser on hand-held device. We recommend the free Adobe Reader.
ACIS.SAB, .SAT2020.1.0RWRW
Autocad.DWG, .DXF2021RWRW
Autocad.DWF, .DWFX2021RN/A
Autodesk Inventor.IPT, .IAM2021RRRequires Inventor or Inventor View of the same version or newer. Solids only. No PMI or colors imported if only Inventor View installed.
Autodesk Inventor.IDW2021RN/ARequires Inventor or Inventor View of the same version or newer. No PMI or colors imported if only Inventor View installed.
CATIA V5 Read**.CATPart, CATProductR29RRCatia V5 Read
EPS.AI, .EPS7,8*RN/A
Geomagic Design.AD_PRT, .AD_SMP2020RR
IGES.IGS5.3RWWMastercam IGES Translator
Solids are converted to surfaces, no views or drawing layouts are available.
KeyCreator.CKD2020RRMastercam KeyCreator Translator
Translator reads solids only
Parasolid.X_T, .X_B, .XMT_TXT32R/WR/W
ProE / Creo**.PRT, .ASMWildfire5/Creo 7RRMastercam ProE Translator
ACC File Required: proE
Raster 2 Vector.JPG, .TIF, .BMPN/ARN/A
Rhino.3DM6RN/A
SolidEdge.PAR, .PSM, .ASM2021RRTranslator reads solids only.
SOLIDWORKS.SLDDRW2021RN/ASOLIDWORKS must be installed for this translator to function.
SOLIDWORKS.SLDPRT, .SLDASM2021RRSolids only. SOLIDWORKS required for Feature History or Sketches.
SpaceClaim.SCDOC2021RRTranslator reads solids only. No assembly support.
STEP.STP, .STEPAllR/WR/W“Part 42” data/AP203, AP214, AP242
Stereolithography.STL1R/WWTranslator creates polygonal mesh entities.
Unigraphics**.PRTNX1934RR
VDA.VDA2R/WWTranslator converts solids to surfaces.
*Solo se admiten las versiones enumeradas.
** Estos traductores no están incluidos en Mastercam y deben adquirirse por un costo adicional. Para más información, contacte con su socio de canal de Mastercam.
