Mastercam Aktarıcılar
Mastercam, çeşitli formatlardaki dosyaların içe ve dışa aktarılmasını destekler. Her bir Mastercam sürümünde hangi dosya formatı sürümlerinin desteklendiğini aşağıdaki tablolardan öğrenebilirsiniz.
Yorumlarınızı ve sorularınızı Mastercam destek birimine gönderin.
Mastercam 2025
CAD Import/ExportExtensionsVersionR/WSolidsAdditional Information
2D PDF.PDFn/aRRead wireframe and text only. To Write, use File-Print and “Print to PDF”.
Dassault 3D Experience.3DXMLR2025xRRCatia V5/V6 Read license required
3D PDF.PDFn/aWWWrite 3D PDF – all entities, levels, toolpaths, stock models. The 3D result is not viewable in a browser or hand-held device. We recommend the free Adode Reader.
3D Mfg. Format.3MFn/aRWWImports meshes. Exports Solids and Surfaces as meshes
ACIS.SAB, .SAT2023.1RWRW
Additive Mfg..AMFn/aRWWImports meshes. Exports Solids and Surfaces as meshes
Alibre Design.AD_PRT, .AD_SMPV24RR
Autocad.DWG, .DXF2025RWRW
Autocad.DWF, .DWFX2025Rn/a
Autodesk Inventor.IPT, .IAM2025RR
Autodesk Inventor.IDW2025Rn/aInventor must be installed on same system as Mastercam. Inventor is creating a DXF for Mastercam.
Catia V5.CATPart, CATProductV5-6R2024RRCatia V5/V6 Read license required
IGES.IGS5.3RWWSolids as surfaces. No views or drawing layouts.
JT.JT10.7RRSiemens 3D file format
KeyCreator.CKD2021RRSolids only.
Parasolid.X_T, .X_B, .XMT_TXT36RWRW
Postscript.AI, .EPS, .PS7,8*Rn/a
ProE / Creo.PRT, .ASMCreo 11.0RRCreo Read Only license required
Raster 2 Vector.JPG, .TIF, .BMPn/aRn/a
Rhino.3DM7Rn/a
Sketch Up.skp2024Rn/aMesh Entities
SolidEdge.PAR, .PSM, .ASM2025RR
SOLIDWORKS.SLDDRW2024Rn/aSOLIDWORKS 2024 must be installed on same system as Mastercam. (Create a DXF in solidWorks as a work around)
SOLIDWORKS.SLDPRT, .SLDASM2025RRSolids only. SOLIDWORKS required for Feature History or Sketches.
SpaceClaim.SCDOC2022RRSolids only
STEP.STP, .STEPallRWRW“Part 42” data/AP203, AP214, AP242, AP242E3
Stereolithography.STL1RWWImports meshes. Exports Solids and Surfaces as meshes.
Unigraphics/NX.PRT2406 Series (until 2406.7000)RRUG /NX 3D Read Only license required
VDA.VDA2RWWExports Solids as surfaces.
Wavefront.OBJn/aRWWImports meshes. Exports Solids and Surfaces as meshes; Wireframe as polylines
