Updated Mastercam Interface
The migration to the efficient, easy-to-use tree-style dialogs continues in Mastercam X4 with the 2D toolpaths. When you select a contour or a drill operation, you will now see a new step-by-step interface.
One of the benefits of this streamlined interface is the ability to effortlessly change toolpath types. For example, if you begin a Drill toolpath (from the menu), select several points or arcs, and then realize when you begin setting parameters that Circle Mill is the better toolpath for the task, you can easily switch styles and continue with your work. There is no need to exit the toolpath and begin again because all geometry remains selected. Simply enter the appropriate parameters and process the toolpath.
