Tech Tip: Verify Selection
Q: What does Verify Selection do?
A: When active, Verify Select lets you sort through entities that are close to each other so that you can make sure you select the correct one. Click the arrows until the desired entity is highlighted, and then click OK.
To make Verify Selection active, click the button on the General Selection ribbon bar:
If you have a good Tech Tip, please forward it to marketing@mastercam.com.
