Mastercam’s Verify Hidden Gem
Did you know that after using Mastercam’s Verify feature to preview your machined part, you can compare it to an external STL model? Mastercam will highlight the differences between the Mastercam part and the STL model. You can even customize this feature with specific tolerances, machining zones, and display colors. Just select the Compare to STL file option when you verify your part.
