When it comes to CNC programming, efficiency and precision are essential. Mastercam’s probing capabilities, combined with If-Then conditional logic, empower machinists to make smarter, automated decisions on the shop floor.
Why Conditional Logic Matters in Mastercam Probing
If your machine controller supports If and GOTO statements, you can unlock a new level of flexibility in your programs. The payoff?
- Less wasted time
- Fewer scrapped parts
More confidence in your machining process Imagine this: You are machining a part where the bore is critical to its function. Why spend hours machining the entire part if the bore is out of tolerance and destined for scrap? With Mastercam Probing, you can check that bore early and decide what happens next—automatically.
How to Use If-Then Conditions in Mastercam Probing
In our example, the part is rough-faced, and the bore is roughed and finished using a circle mill. After that, a probing toolpath checks the bore size. Depending on the result, the program can:
- Skip ahead to later operations if the bore is in tolerance.
- Continue machining if the bore is undersized.
- Stop the machine and alert the operator if the bore is oversized.
This logic is set up in the Cycle tab of the probing operation. Here, you define:
- Geometry and size of the feature being probed.
- Tolerance limits for the bore.
- If-Then conditions that dictate what happens next.
Real-World Example
In the settings used for this part:
- If the bore is on size, the program jumps ahead to the next group of operations, skipping extra finishing and probing.
- If the bore is undersized, it runs a secondary finishing pass and probes again.
- If the bore is oversized, it triggers a manual entry with a Fanuc error code, stopping the machine and notifying the operator.
If the bore remains undersized after the second probe, the machine can automatically adjust tool offsets, even by a percentage of the difference to avoid overshooting. After adjustment, the program loops back to re-machine and re-probe until the bore meets tolerance.
Mastercam Probing: Behind the Scenes
Looking at the posted code, you will see GO TO lines with sequence numbers added automatically. These allow the machine to jump between operations based on probing results, giving you complete control over the workflow.
The Payoff
With these settings, your machine can:
- Compensate for tool wear without operator intervention.
- Reduce wasted time and material.
- Enable lights-out machining for critical features.
And the best part? This approach is not limited to bores—you can apply it to any measurable feature that is critical to your finished part.
Watch Mastercam Probing If-Then Conditions in Action
Mastercam Probing with If-Then conditions is more than a feature—it is a strategy for smarter, more efficient manufacturing. Ready to optimize your process? Log in to myMastercam and watch the full video!
In Summary
Automate Decisions: Use If-Then logic to control machining steps based on probe results.
Reduce Scrap: Check critical features early to avoid wasting time and material.
Boost Efficiency: Skip unnecessary operations when parts meet tolerance.
Enable Smart Machining: Combine probing with conditional logic for lights-out manufacturing.
