Machine Misconceptions
Today we’ll talk about a common misconception surrounding the type of machining that Dynamic Motion delivers.
Some assume toolpaths that are designed for fast, controlled cuts are intended for use on special high speed machines. The truth is that Dynamic Motion is built to give you a benefit on virtually any milling machine you run – old or new. It’s certainly true that newer and more sophisticated machines can output parts with greater efficiency, but you’ll see dramatically benefits using the toolpaths with even an old retrofitted machine.
And with our expansion of Dynamic Motion to turning, you can get better performance from your lathes as well.
So, no special machines needed for using Dynamic Motion technology. Just the desire to finish faster, cut smoother and to make the most of the machines you already have.
