Did You Know That You Can Create Adobe® PDF and Autodesk® DWF Electronic Documents with Mastercam?
Maybe you want to save everything electronically but don’t need all the features of expensive PDF creation software. CutePDFTM Writer installs as a printer that you use to create a PDF file.
To create PDF files from Mastercam:
1. Go to http://www.cutepdf.com/Products/CutePDF/writer.asp and follow the installation procedure.
2. When you print, select the CutePDF Writer as the printer. This creates a PDF file from your Mastercam file.
PDF files let you send your customer electronic documentation of the Mastercam job in a format that everybody can view.
Autodesk has a similar product called Autodesk DWF Writer for 2D. This utility is similar to SOLIDWORKS eDrawings and can be installed to make electronic documentation of a CAM job.
