Diversifying to Stay Competitive
Industrial Machine & Supply (IMS) was once a leading manufacturer for textile mills but needed to diversify as the textile industry waned in its area.
Product Used:
Mill, Lathe
Automotive, Consumer Goods, Agriculture
PROJECT DETAILS
When Industrial Machine & Supply, Inc. (IMS) was founded in 1967, its niche was firmly set in supplying parts for textile mills in the Southeast. But by the time founder Tom Williams stepped down to allow his son David Williams to take charge, the textile industry in their area had ebbed drastically. IMS could no longer thrive on just one market.
The younger Williams made the decision to expand IMS’s capabilities to serve international industries like material handling, agriculture, automotive, and consumer goods. “We’re basically a job shop. If it’s in our envelope, we’ll machine it,” said Williams.
With this diversification came the need for more advanced technology. “I was looking at jobs I knew I could get if I could just write the programs,” Williams recalled. He knew that IMS needed a powerful CAD/CAM software to work alongside its 3-axis CNC milling machines and 2-axis CNC lathes. Manually writing G-code wasn’t an option for his evolving shop anymore. The time it would take to accurately program by hand the complicated parts Williams wanted to create was prohibitive, and he was well aware of the risk of user error inherent in complex code writing.
Williams went to the 1998 International Manufacturing Technology Show (IMTS) to find a solution. There he met Allen Drost Jr., founder of CAD/CAM Solutions, Inc. (Snellville, GA), certified Reseller of Mastercam CAD/CAM software for Alabama, Georgia, and Tennessee. “Drost came directly to my shop after the event, loaded Mastercam on my computer, and ran a part right in front of me. He sold me on the software right there.”
David Williams working in Mastercam.
“With this software, I’m able to take on complex jobs I could never even look at before,” said Williams. Several years ago, Williams machined a facial extrusion die for the composite decking industry that would not have been possible without his CAD/CAM software.
Now he knows he could be even more efficient with some of the new functions that his software is constantly developing. “That was several years ago, and if I were to do this same part today, I would look at different toolpaths such as OptiRough for roughing out the part,” said Williams.
“Another one of our longtime customers just brought us a job that we’re very familiar with and have done before. This time, though, I said, ‘We’re going to do this differently now,’ because there are so many more toolpaths I understand now that can make this easier,” he said. “We might have done a particular job before, and it would have taken us longer and cost us more than it would now. The Dynamic toolpaths have really changed the way I look at some of the jobs we get.”
The Backspot face tool is used in the ship building industry - attached to a mandrel.
Dynamic Motion technology, or simply Dynamic, uses a revolutionary approach to maximize cutting ability while minimizing stock, tool, and machine danger. Dynamic toolpaths rely on proprietary algorithms to monitor the stock material at all times and to make immediate adjustments to cutting speed and angle. This way, the most material possible is removed while virtually eliminating the chances for tool breakage and stock gouges. OptiRough is one of these advanced toolpaths and is a go-to for removing great amounts of material in the roughing stage at previously impossible speeds.
True to form, IMS’s software is just as diverse as its shop. Williams relies on Mastercam before he even begins a job. “It helps with quoting,” he explained. “If I have a complex job – especially one that has a lot of parts to it or maybe quite a few steps and operations – I semi-program it to see my cycle times.”
Recently, Williams was called on to provide a quote for some rollers that work in a conveyor system. The v-rollers, as Williams refers to them, start as 4” diameter, 21 5/8” long bars of 4340 tempered steel. To create his quote, Williams uploaded the drawing into his software and programmed out the part to find his cycle time.
“For roughing, I could have used a traditional turning toolpath with extra step-downs if I’d wanted the cutting path to go in just one direction. With the Dynamic toolpath, though, it actually went back and forth all the way down. It saved so much time.” Williams was able to run at 1,050 surface feed per minute with a 25 percent stepover. The program, which had approximately 15 operations, took less than 11 minutes to rough before it was finished with a standard contour toolpath. Because he could cut so much cycle time with Dynamic Motion, Williams was able to present the customer with a more-than competitive quote and earned the job.
Now turning away work for being too complex is a thing of the past. When asked what IMS is capable of producing, Williams answered, “Pretty much anything. If you have any machine work to be done, send it our way; we’ll do it.”
“With this software, I’m able to take on complex jobs I could never even look at before.”
—David Williams, President, Industrial Machine & Supply, Talladega, Alabama
Expanding IMS’s machining capabilities with the machines they already had
THE SOLUTION
Mastercam Mill and Lathe
  • Network of knowledgeable, experienced Resellers who can introduce and explain new techniques and functions.
  • Intuitive toolpath creation that minimizes computer time.
  • Advanced Simulation that can predict cycle times.
  • Dynamic Motion technology that reduces machining time safely.
HoistDrum Machined
Mill
3D-Machine, Inc.
Learn More
Achates machine shop team using Mastercam
Mill
Achates Power
Learn More
Allstrap
Productivity+
Allstrap Success Story
Learn More
Machining a 1 mm chamfer with Mastercam.
Mill
AMADA TOOL AMERICA, INC.
Learn More
APS
Mill
APS Plastics Success Story
Learn More
Asnuntuck Machine Demo
Education
Asnuntuck Community College
Learn More
ATC students with Mastercam University certificates
Education
ATC Machining Technologies
Learn More
Bloomsburg High School Macine Shop
Education
Bloomsburg Area High School
Learn More
Cal Poly Mustang Rough Thumbnail
Education
California Polytechnic State University Uses DFM to Improve Engineering Skills
Learn More
Candor Bulldozer Thumbnail
Educational Suite
Candor Central High School
Learn More
Complex Parts Made Using Mastercam at Carolina Precision Components
Multiaxis
Carolina Precision Components, Inc.
Learn More
CVC Students and Professor
Education
Catawba Valley Community College
Learn More
CETech Innovations Owner Corey Easter
Job Shop
CETech Innovations
Learn More
chippewa Tech Student in mastercam
Education
Chippewa Valley Technical College
Learn More
Router in action
Woodworking
CNC-Siponen Oy
Learn More
Multiaxis
Coordinate Industries Ltd.
Learn More
3 pound double mount
Mill
Cornfield Crappie Gear
Learn More
Diversified Metal Crew
Mill
Diversified Metals Services, Inc.
Learn More
Quality Check
Mill
Don Schumacher Racing
Learn More
UAV Flight Components
Mill
Flying S, Inc.
Learn More
Mill
Grayco Machine Ltd.
Learn More
Profiling a calibration block
Tool & Die
Houston Mold & Tool, Inc.
Learn More
Mill
Learn More
IUPUI Part engraved
Educational Suite
IUPUI School of Engineering and Technology Success Story
Learn More
Jacob Grey Cam
Mill
Jacob Grey Success Story
Learn More
Classroom of students
Education
Knox County Career Center
Learn More
Colter Kaspar Thumbnail
Mill
Kormachine
Learn More
Chest set
Education
Lincoln College of Technology Teaches Students CAD/CAM Programming
Learn More
Alex L and Kevin S Thumbnail
Mill
Loper Machine LLC
Learn More
MRS complex machined parts
Aerospace Defense
M.R.S. Machining
Learn More
Machine Nunn Thumbnail
Mill
Machine Nunn
Learn More
Madtown Skidplate
Mill
Madtown Guitars
Learn More
Multiaxis
Magnuson Products
Learn More
Mallory
Mill
Mallory Industries Success Story
Learn More
McAfee Machine Shop Thumbnail
Mill
McAfee Tool & Die
Learn More
Employees at Monsees Are Cross Trained
Design
Monsees Group
Learn More
New Bridge High School student using Mastercam for machining.
Education
Learn More
Spray Paint Gun in Mastercam
Mill
Northwood Industries
Learn More
NOVONestPlate
Lathe
NOVO Engineering
Learn More
OldenburgTechMachine Thumbnail
Mill
Oldenburg Metal Tech, Inc.
Learn More
Mars Rover image
Aerospace Defense
Pacon Manufacturing, Inc.
Learn More
Platt Instructors thumbnail
Education
Platt Technical High School
Learn More
Progressive Tool Employee Group Shot
Mill
Progressive Tool and Manufacturing, Inc.
Learn More
Education
Reed-Custer High School Guitars
Learn More
Mill
Revolution Speed
Learn More
Mill
RockQuality Consulting
Learn More
Mill
Royell Manufacturing, Inc. Uses Mastercam to Become a Tier 1 Manufacturer
Learn More
CAMIT Students in Shop
Education
Spartanburg Community College
Learn More
Specialized Bike Thumbnail
Consumer Goods
Specialized Bicycle Components
Learn More
Springfield Tech Community College
Education
Springfield Technical Community College
Learn More
Stark State Machine Shop thumbnail
Education
Stark State College
Learn More
STCC Students and Professors
Mill
STCC Summer Camp
Learn More
Car on Track Thumbnail
Mill
Stewart-Haas Racing and Mastercam Dynamic Motion
Learn More
Insulator Programmed in Mastercam
Productivity+
The H-J Family of Companies Success Story
Learn More
Mill
Titletown Manufacturing LLC
Learn More
Trent Turner
Mill
Toner Machining Technologies
Learn More
Triple C Employees
Mill
Triple C Machine
Learn More
UCONN FSAE team
Educational Suite
UConn Formula SAE
Learn More
Tony and Alex Johnson
Aerospace Defense
United Machine & Metal Fabrication
Learn More
UTI Instructor in CNC Shop
Education
Universal Technical Institute – NASCAR Tech
Learn More
Van Buren Thumbnail
Educational Suite
Van Buren Technology Center
Learn More
Jess and Ben in Machine Shop
Mill
Van Dam Custom Boats
Learn More
Venom Outdoors
Mill
Venom Outdoors
Learn More
